milosh wrote:SR-71 wasn't agile at all but couldn't be down because at altitudes that thing or MiG-31 operate missile controls are very ineffective so even if you have just 2G capability you can easy evade missile thanks to altitude and speed.
So MiG-31 will do same thing but with much higher G limit.
AIM-54 was tested against something which could be consider MiG-31 like target (high altitude, high speed) and it was able to hit it, don't know did target do evading maneuvers, because it could be test against Kh-22/32 like target and those don't turn. For AIM-120D I didn't find nothing similar was done.
Just because you didn't find an AIM-120D test against such a type or target doesn't mean it's not capable of it. Actually I think that both me and hornetfinn clearly explained you why the AIM-54 won't have any advantage over the AIM-120D when engaging very fast and high altitude target.
There's no need to repeat myself, is there?
milosh wrote:If we talk about electronics why just focus on cockpits of 1980s? What about digital datalink in F-15 or F-16 in 1980s? Can you please point out capabilities of those to compared them with this:
https://www.secretprojects.co.uk/thread ... nks.33542/This was what you will have in Su-27, MiG-31 but also MiG-23 and MiG-29 (though less capable, one way datalink I think), don't know about MiG-25.
The Mig-29 didn't have data-link and neither the Mig-23! Only the Su-27 and Mig-31 had them. But we can basically rule out the Mig-31 since these would be kept flying over Soviet Union defending the airspace from incoming aircraft such as strategical bombers.
These leaves the Su-27 as the only Soviet aircraft with datalink that could potentially fly over Central Europe. The Su-27 datalink while existing was crude and a bit technologically backward even at that time.
The F/A-18 had datalink which was far more advanced than the Su-27 could ever dream of.
The F-14 also had datalink. So, even if you still want to include Mig-31s on the Soviet side then we must include F-14s on the NATO side.
The F-15C and F-16 didn't have datalink at the time if I'm not mistaken but they were fully integrated with a NATO AWACS network (although by voice information only) which the Soviets/Warsaw Pact could only dream of.
milosh wrote:Btw reason why Soviets had less modern cockpit was familiarity, they even make similar instruments compared to MiG-15 for example.
LOL, that's comical at best!
So and according to your logic the US Air Force and US Navy should never had put modern "glass cockpit" on their F-15, F-16, F/A-18 because it made less familiar compared to the F-4 Phantom, F-105, etc... which pilots operated earlier on?
Or moving to modern times, the F-35 should have MFDs instead of a touch screen and Helmet display because it also "breaks" pilot familiarity?
Nope, the reason why Soviets had less modern cockpit was because they were massively behind in terms of electronics and computer technology specially miniaturized tech of this nature, which are requirements for being able to develop and implement "glass cockpit" on combat aircraft. This is not an opinion - it's a FACT!
And the Russians only managed to implement "glass cockpit" on combat aircraft such as Su-30, Su-35, Mig-29M, Mig-31M, etc... after the end of the Cold War and because the French gave them the tech to do it so in the 1990's and therefore out of the scope for this discussion (Cold War era).
