ricnunes wrote:mixelflick wrote:...
So perhaps the USMC was right in ditching their tanks, at least in some scenarios...
I disagree. Or more precisely I tend to disagree with a good part of your post while agreeing with some other parts.
I agree when you say that modern anti-tank weapons like the Javelin or suicide drones are extremely dangerous to Main Battle Tanks (MBTs). But then again if those weapons are so dangerous to MBTs then imagine how much more dangerous would they be against lighter armored vehicles like IFVs or APCs?? Or even against dismounted infantry?
The thing is that in order to assault an enemy fortified position you'll need armored vehicles that can provide both cover and fire support to the infantry.
Are you going to send dismounted infantry to assault an enemy fortified position? History have been showing us that this would basically be a suicide tactic.
And here is where the importance of Main Battle Tanks, specially well armored and survivable tanks like the western designs (namely M1 Abrams, Leopard 2 and Challenger 2) come up. They provide a way to assault enemy fortified positions head on while minimizing human loses since if one of those tanks is destroyed/mobilized by enemy modern anti-tank weapons or suicide drones the crew will have a much bigger chance to survive than being inside a more lightly armored IFV.
In the way, what Ukraine is showing us but in fact we already knew is that integration between several assets - the so called "combined arms" - and all of these assets being networked is absolutely vital for future success and survivability in the battlefield. And the Russian have been failing miserably at this and on top of this, their Tanks are poorly designed for crew survivability hence why (IMO, without surprise) we have been seeing their armored columns/tanks failing so miserably!
Resuming if you are about to be hit by a modern anti-tank weapons like the Javelin or a suicide drone would you rather be inside this:
Or inside this:
Have to agree with you here. You can't trot out a fleet of t72's, likely from storage, with the ERA side bags empty on many of the older t-72's. Also, the last second try at cage armor was a flop. Plus using Russian tanks as the reason the tank is dead is not a hard to point at poster child. The reality today is there are probably 3 or 4 potentially missiles that can hit an Abrams near the front with any shot of pentration; Most of the Russian models or like can't get through what an M1A2 is packing, and if it's an M1A2C, well, the rumors of what the armor equivalent are is immense in certain spots. even the side armor is very good, with thought that only the last two guns procured by the Russians can get through the side armor, let alone the front. The penalty is weight of course, with the estimates anywhere from high 70's to 83 tons when fully loaded up. But the immense armor, the ARAT ERA plus Trophy would make an Abrams very tough to kill. The thing I see alot from geniuses like the fool at Task & Purpose "NLAW's would kill an Abrams". Considering Trophy does have a protection ability for top attack rounds, that basically means right now the best way to attack an Abrams is with an IED that is not remote-controlled detonated or by a Sabot round from the latest guns through the side or rear. The losses you see from Saudi's using them or the Turks and their Leopard 2's are often rear shots, no APS, and it's a lose lose. Though these tanks then blow vented up and out the ammo, or get a new engine, and live to fight another day with a saved crew. They don't play cook up and blown out the jack in the box top. Honestly, my thought is you will see more attention given than even currently to APS systems and see what the NATO armies do best- add more armor where needed. Top attack ATGM are not like an ASM going from low altitude to a high last second approach to dive down the ship; Instead they shoot over a projectile from very close distance on the top armor. It probably has much less explosive equivalent than most Anti tank weapons. Put more armor on top of the tank and perhaps engine compartment and ball is back in court of the missile makers to figure out can they upgrade the kill ability or would the missile not be capable of that power output for top attack? If the US ever gave as much to its R&D to the Army as it did its Air Force they probably by now would have 140 mm guns on the tanks, needed or not, have put on hybrid drives for the engine but most importantly, fixed the Armor dilemma of the new magic material combination to drive the weight down by a third or half, which may be this foam metal (the look, not really foam) with the hollowed spaces with a combination of other materials over composite with even some advanced aluminum or such. But the advances have not kept as much pace as say Aircraft advances, and that's entirely due to the Russians slacking off on their armor and China being so, so far behind to begin with.
