jessmo112 wrote:tphuang wrote:weasel1962 wrote:A bit skeptical here. The original FC-31s used RD-93 (2x19k lbs). The prototypes appear to use WS-13s or WS-13Es (19-22k lbs). It takes years to develop new engines. Considering the speed at which the J-35 test units was redesigned from FC-31 and built, they'd have to go with matured engines which means WS-13(Es). There is always talk of new engines eg WS-19s (25k lbs) but engine investment went first into WS-15s for the J-20s and even then it took time before WS-15s went into J-20 production units. Early production units, if adopted (and that's a big IF) would fly with WS-13s.
PLAAF never went for the FC-31, since they had the J-20 and a 20k lb thrust advantage. imho, the J-35 is nowhere close to F-35 capability. Unclear what the PLA Navy direction is on J-35 adoption. Even with matured engines, it'd take years before J-35 enters production. Initial air wing should be J-15Bs. J-15 production line is already humming.
Yes, they use WS-21 (WS-13E) engines. It's been around for a while. The entire WS-13 series has basically been the de facto engine on the larger drones. Currently, any non Pakistani JF-17 export is using WS-21.
The aircraft itself is about the same size as F-35C, so the T/W ratio should be fine with just 2 WS-21. From what I can see, it looks stealthy enough. I don't see any reason why it can't be in the same rough ballpark as F-35C in radar signature. The weapon bay is sufficient large to hold enough 6 AAMs. AESA radar, EW suites and situation awareness are currently strength for the Chinese defense industry. I don't see any issues there.
I'll find it later, but I already read an article recently discussing how the plane has already gained over 3k pounds. And this is with out the hook, reinforced landing gear, added wing an any other such add ones.
To say that this plane might only gain 5k in extra pounds is generous the 4-5k in added thrust will be swallowed up in development weight. I even saw pictures of the adding smaller bays in the wing roots.
I believe it was someone at Lockheed that said "empty space is heavy"
The WS-19 comes across as vapor-ware at this time.
Endless cycles of promises always promising a leap forward in engine technology, only to admit defeat years later.
Keep in mind that F-35C is 15.7t in empty weight, which is 2.5t more than F-35A. So, it would actually be normal for naval version to be 4 to 5k lb heavier. I have no insight on how much heavier J-35 is over the land based FC-31.
You will see that J-35 has taken the same changes that F-35C did like larger wing/jail fin + the hump behind the cockpit (compared to the land based version). I think the two aircraft are about the same size/weight and 2 WS-21 will generate the same thrust as 1 F-135. Even if it's T/W ratio is a little worse than F-35C, it's not end of the world as long as its radar signature/weapons/radar/EW suite as in the same ballpark.
If I were SAC, I'd be a little embarrassed about how much J-35 looks like F-35C, but that seems to be all the are capable of. CAC, who developed J-20 and is likely the 6th gen developer, is far more capable of developing new stuff.
Keep in mind that China does not export its best stuff or even close to it. It only just now exported 054A and J-10C to Pakistan. Both of which are reaching the end of their production run in China.
