jessmo112 wrote:China has maybe 50+ J-15s ATM which isn't enough to fit 3-4 carriers. They could have the J-35 before 2030 but your betting on.
1. China to finally achieve engine parity with the west and get a credible power plant on the J-35.
As of right now the power and reliability of the
RD series of engine I'd not up to the task of what would ne required for naval deployment.
Someone mentioned before on this board about launching in only burners to achieve takeoff weight.
RD series will burn out fast with that.
2. Even if they get an engine to naval standards, do you expect to throw more wing weight, and gear on the thing, and all will go smooth?
We only need to look back to the hornet wing drop issue, and the F-35C hook issue, to see how complicated this is
To bet on no delays or problems is a bad bet.
3. Full integration.
The J-15 is a dead end. It's already coming to the fleet outdated. And it's seriously flawed.
IMO if they wanted to copy a 4th generation fighters they should have copied the Super bugg design.
A massive naval aviation short fall is China problem.
The Fujian is essentially a modern version of the Kitty Hawk, which is not as capable as a Nimitz but still very formidable, no one here would dismiss a Kitty Hawk in terms of capabilities.
If China wants to have 6 supercarriers by 2030, then I doubt they'll make a completely new carrier and likely will just make improved Fujian types, otherwise the development time and costs would be far too much to realize their timelines. It won't match the US Navy, but almost all other navies will be overmatched.
The J-15 is not a dead end, especially with the J-15B version getting closer to production with AESA radar (probably shared with the J-11D and J-16) and catapult launch nose gear. It's probably quite competitive with an F/A-18E/F Super Hornet Block II, although I think the Block III would probably have better avionics and mission systems. But the F-35C is clearly superior and frankly we're not investing enough in the F-35C production.
