Time for 100K lbs of AB Thrust?
Corsair1963
Unread post14 Oct 2021, 01:18
sferrin wrote:Re: Follow on engine size (NGAD) this is from this weeks AvWeek:
Is the NGAP an Adaptive Cycle Engine like the XA100 & XA101???
sferrin
Unread post14 Oct 2021, 03:33
What's, "NGAP" stand for? :wink:
Corsair1963
Unread post14 Oct 2021, 04:48
NGAP stands for Next-Generation Adaptive Propulsion. Yet, does Adaptive Propulsion mean the same as Adaptive Cycle? Hence my question..........
hkultala
Unread post14 Oct 2021, 11:15
IMHO
Something with both core and fan sizes similar to F119, with maybe slightly more thrust due to higher pressure would be enough for NGAD. And then in the economy mode the effective core size would be smaller.
AFAIK the main improvements of NGAD vs f-22 are range and even lower RCS.
Because the economy mode gives much better subsonic fuel-efficiency compared to F119, range of NGAD would be better even if it was just re-engined f-22, so the plane does not have to be much bigger to have better much better range than what f-22 has. Also, they could even survive with slightly lower AB t/w ratio than in f-22.
But for F-35, bigger core (than in F135) is desired for better dry thrust improvement, mostly for better supercruise. And bigger fan (than in NGAP) is desired to 1) have more air for more AB thrust 2) get high bypass ratio for good fuel ecomomy when core size is also increased while keeping reasonable dry thrust.
sferrin
Unread post14 Oct 2021, 12:33
Corsair1963 wrote:
sferrin wrote:
Corsair1963 wrote:Is the NGAP an Adaptive Cycle Engine like the XA100 & XA101???
Yes. Why would they spend all the effort to put it into a new engine for the F-35 and then leave it off in the NGAD engine?
Previous
Users browsing this forum: No registered users and 33 guests
