Not only will the good old boys argue for a clean sheet design they'll up the anti on the systems it flies with to make sure the F-35 can't compete. A larger radar array up front makes sense with the decreasing RCS's of opponent aircraft and the use of the array for jamming. No matter how you slice the pie a larger array gives you more power. Think in addition you will see side arrays to give the pilot more than a 120 deg. field of view. I'm thinking maybe even a little more than 180 deg. The F-35 makes for a good modern "light attack/strike" aircraft like the A-4, A-7, and F/A-18A/C but just based on physical size can't compete in some respects to a large fighter.
The admirals will need to supply congress with some reason to keep the existing and build new carriers after noting that they're vulnerable due to the lack of range of the air wings embarked. A new longer range strike aircraft/fighter will be it. I found the Proceedings article enlightening. Think the extended air battle coupled with long range strike will be the focus of their efforts. Wonder what we'll hear from the briefings and seminars at Tailhook? Anyone remember the discussion prior to 9-11 on the sunset of the carrier? If OEF had not occurred the carrier force would be markedly smaller now. Will try to dig up an article from that period from Parameters which discussed this topic. I've found that the journals from the various war colleges to be great sources for understanding these issues. After all they act in part as think tanks.
