F-15EX
Maybe he was doing his slow speed pass in a very stiff head-wind which further reduced his Ground Speed? Nothing against the Strike Eagle but when I saw its demo a little over a decade ago it wasn't particularly impressive. Agile Eagle program which put leading edge slats on E/S Phantoms, I believe, was originally conceived for the F-15. Yet at that time McAir figured that the Eagle was already dominant and it wasn't justifiable. But one must wonder what a variable camber Leading Edge would have done for that jet at lower speeds?
Here is an E model, with no CFT's and pure power from those -229's.
And in the video the jet doesn't even hardly stay in ground effect, yikes......
https://www.youtube.com/watch?v=Bp8k3vY3qGU
And moldie oldie C model from 30yrs. ago
https://youtu.be/w3xhrtvrHZ4?t=2046
It appears the old Eagle design still has lots of life left in her. I am a bit curious to see how much the new fly by wire system improves the low speed handling characteristics. Will the old dog have a few new tricks? I've heard rumors that these latest Eagles can actually pull off controlled tail slides, though I do not know if such rumors are true. I also hear it is capable of some other pretty nice high alpha stuff. And we know it certainly has the power to offset the weight it has gained over the years. I kind of hope they just stick with the GE F110 engines as standard, as that is a helluva nice power plant.
Both the F100-220/229 and F110-100/129 were designed with a mechanical throttle connection to the airframe, although they both have 1553 Mux Bus interface with the airframe.
If the F15EX/F110-129 has redesigned their engine control system to eliminate the mechanical input and operates completely under 1553 mux commands, the F100-229 integration will not be simple. But if all they have done is install an electric throttle that turns the mechanical input to the engine control, the -229 integration is probably only a paperwork exercise since they are already standard equipment on the F-15E.
Fox1 wrote:It appears the old Eagle design still has lots of life left in her. I am a bit curious to see how much the new fly by wire system improves the low speed handling characteristics. Will the old dog have a few new tricks? I've heard rumors that these latest Eagles can actually pull off controlled tail slides, though I do not know if such rumors are true. I also hear it is capable of some other pretty nice high alpha stuff. And we know it certainly has the power to offset the weight it has gained over the years. I kind of hope they just stick with the GE F110 engines as standard, as that is a helluva nice power plant.
If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat. I think the 229 is lighter, but the F-110 has stingier fuel consumption. I'm sure engine guy will know.
Either way, our pilots are getting a terrific engine..
mixelflick wrote:If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat.
If you look at the flight envelopes and acceleration charts in the HAF F-16-1 you can see that the brochure ratings don't mean much. The F110 has superior performance to the F100 in many regimes.
sprstdlyscottsmn wrote:mixelflick wrote:If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat.
Well, if that's true then I'm sure it really frosts P and W. Not so sure if I was them though that I'd go through the time and expense of building an "F-110 killer"/new F-100. They need to deliver thousands and thousands of F-135's for the F-35, which can't be an easy or inexpensive endevour. The total market for advanced Eagles is what, in the 100's..... maybe?
And most are already flying with GE motors. Saudia Arabia, Quater, ROK, Singapore did a split buy and now USAF. I'm not an engine guy, but it seems to me once those motors are entrenched in a fleet they're difficult to replace. The Israeli's and Japanese? OK, maybe. India? Very unlikely IMO they go with the F-15EX..
If I were Pratt, I'd take a pass on this one and focus on the F-135, F-119 and whatever's next for NGAD/PCA.
mixelflick wrote:If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat. I think the 229 is lighter, but the F-110 has stingier fuel consumption. I'm sure engine guy will know.
You are looking at old version of F110, the newest version(F110-GE132) has over a tonne more, 32500lbs
hkultala wrote:mixelflick wrote:If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat. I think the 229 is lighter, but the F-110 has stingier fuel consumption. I'm sure engine guy will know.
Except they're not using that variant. They're using the -129 version.
and FWIW both Pratt and GE have 32k class motors that actually put out over 35k+ and neither of them have an actual customer (outside the F-16E)
wrightwing wrote:hkultala wrote:mixelflick wrote:If I'm not mistaken, both the GE F-110 and P and W F-100-229 both generate around 29,000lbs of thrust in max reheat. I think the 229 is lighter, but the F-110 has stingier fuel consumption. I'm sure engine guy will know.
Right. I'm sure they have their reasons be it $, having plenty of thrust already, durability/engine life, TBO, fuel efficiency... something. It's probably fair to say it won't be lacking in the "umph" category and besides, thrust is just part of the equation. The other big factor is drag, and given what it's capable of carrying they'll be plenty of that LOL.
Clean though, or nearly so? Should be absolutely frightening, given what we already have seen from the other "advanced" F-15's flown by SA, Quatar etc...
sprstdlyscottsmn wrote:and FWIW both Pratt and GE have 32k class motors that actually put out over 35k+ and neither of them have an actual customer (outside the F-16E)
And they've had them for decades. A damn shame that more didn't buy them. Imagine an F-15C or Tomcat with 72,000lbs of thrust.
sferrin wrote:sprstdlyscottsmn wrote:and FWIW both Pratt and GE have 32k class motors that actually put out over 35k+ and neither of them have an actual customer (outside the F-16E)
From conversations I had with the guys at Edwards, the F-15 ACTIVE has them. As for the Kitty, a TF30 is bigger than an F119, so why half a$$ it with a stronger F110? The F119 has Mil power comparable to the TF30 in burner over much of the flight envelope.
But I digress and talk of F-15C or Tomcat is off topic. The truth is that 129s give plenty of AB power for even a heavy F-15EX. I really think the F-15 is wing loading limited now.
March 29, 2021
An unlikely competition to supply the engines for the U.S. Air Force’s future lots of Boeing F-15EX fighters will soon come to an end. Bids are due April 7 from the familiar F-15 engine rivals—the GE Aviation F110 and Pratt & Whitney F100—for the largest single fighter propulsion system contract.
https://aviationweek.com/defense-space/ ... =114923889
Pratt & Whitney Submits Proposal to Power the F-15EX with the F100
Pratt & Whitney is proud to have submitted our proposal to power the USAF F-15EX with the trusted F100-PW-229 engine for Lots 2-9 of the procurement schedule. The F100 engine has powered every operational F-15 in the USAF fleet since its first flight in 1972, and we look forward to powering this legendary fighter for decades to come. The F100-PW-229’s power, performance, and reliability will enable the F-15EX to conduct the Air Force’s most critical missions here and abroad. With more than 28 million hours flown by 23 nations, the F100 has proven itself an invaluable asset for our customers around the world, and our extensive sustainment network at USAF F-15 bases worldwide will ensure the engine is mission ready and delivers excellent value and superior capability to the U.S. Air Force as it conducts global operations.
https://newsroom.prattwhitney.com/Pratt ... h-the-F100
April 7, 2021 | By Brian W. Everstine
The Air Force’s newest fighter jet has a name: F-15EX Eagle II. The service unveiled the name of the jet during an April 7 ceremony at Eglin Air Force Base, Fla.
The Air National Guard will be the first to receive the new jet operationally. ANG Director Lt. Gen. Michael A. Loh said during the ceremony the F-15EX’s improvements will be key to its mission of homeland defense.
https://www.airforcemag.com/f-15ex-named-the-eagle-ii/
