sprstdlyscottsmn wrote:zero-one wrote:What kind of advantages will the 129 bring to the F-15 airframe? will it bring the F-15EX back to the F-15A levels of performance? I remember you saying that the F-15A was the absolute best in terms of turn rates or basically all dogfighting relevant performance. Or will the naked EX surpass the A models?
Anyway, the only advantage of the CFT less Eagles is performance, and the F-22 already gives the USAF all the performance it wants. So I don't see the USAF wanting it, they'll find a long range, heavy weapons truck more useful. But I can see why the ANG could probably want it.
The F-15EX will smoke the A in acceleration and climb, but it is still heavier so it will not do as well in ITR turns. STR turns is harder to say because the 129 will bring a lot of extra power over the F100-PW-100 of the A, but the added weight is squared in terms of induced drag added. For example, an F-15A with 8AAMs and 69% fuel (to get a total fuel fraction of 20%) weighs ~41,200lb. The empty weight of the F-15EX without CFT is 6,000lbs higher (34,000 vs 28,000) for a 14.6% increase with the same payload. So for a given q (dynamic pressure) and n (G-load) the EX has 31.2% extra induced drag. It is likely higher as the way the same n is reached at the same q for the higher weight is more Cl from more AoA which lowers the e (Oswald's efficiency factor) value. Form drag will be largely the same but for these STR conditions it will account for about half the drag at peak STR (AoA for L/D max gives max lift for a given value of thrust/drag) and less than half at lower speeds. So the GE-129 needs to produce on the order of 16-25% more dynamic thrust than the PW-100 to match the F-15A STR depending on speed range.
EDIT* Forgot to answer part two. You are bang on there because once it was shoved into the budget the USAF wanted to two seater as a new Strike Eagle and the ANG wanted the single seater for air-defense
From low level maneuvering standpoint the PW229 equipped Strike Eagle is also very agile at low level, airshow environment, if the CFTs are off. Th PW229 has a same static thrust preformance, while the dynamic is a different animal, even if Pratt&Whitney charts shows the same. Based on what the EX pilots said. Maybe I just missed the point and the significant difference is only comes with the speed and altitude.
But since the EX is even more heavier than the E model, the STR or especially the low speed, the high AoA maneuvering characteristic could be not so good, since the low speed thrust differnece between the PW229 vs GE129 is not so high.
The only thing what would be at the EX side is the FbW, which is able to let some room at the high AoA limits for the pilots.
When the first F-15EX 001 did the first flight, the Boeing test pilots managed some zero speed post stall maneuvering, when the fuel level let it them.
