basher54321 wrote:zero-one wrote:
The 129 could be seen slowly but steadily inching away from the 229.
You would need to know the weight of both in those tests - the PW F-16s weights were often given about 800 lbs lighter.
The flight test data on the other hand compares at the same weight where the 129 does show a significant thrust advantage. However does that simply carry over to the F-15? - no idea.
Apparently, the difference is substantial (at least in burner) - but I'm not sure which Pratt F-100 they used in the "old" F-15C. Direct quote from Retired USAF Gen. Paul Hester...
https://www.airandspaceforces.com/why-i ... fs-f-15ex/“When I got to Eglin, I inherited a program integrating the (F110)-129 engines on the F-15,” Hester said. The upgrade added 4,500 pounds of rated thrust to each engine and unrestricted throttle movement. When Hester sat in the back seat of an F-15 with the old engines and flew alongside another F-15 equipped with the F110-129 engines, the difference was apparent.
The two planes were separated by just three or four aircraft lengths at 10,000 feet at an airspeed of roughly 350 knots. “Then came the order to approach military power”—maximum speed without afterburners.
“The GE-powered airplane steadily moved out front and accelerated away from the one I was flying in,” said Hester, who went on to command Pacific Air Forces. “The difference in military power was impressive. It just put a smile on my face.”
Then the two Eagles came around and lined up again. This time, the order called for full afterburner. “And here’s where you got to notice the real difference between the two airplanes, one powered at 25,000-pound thrust and the other at 29,500-pound thrust,” Hester said. It was a significant jump in capability, and seeing that, well, I wanted to be checked out on the F-15 again!”
No idea as to loadout, fuel etc. but one would assume if this comparison was made, they were similar. That, combined with the comments about the EX getting "higher and faster" during exercises is telling IMO. But who knows, lots of things usually play into these comparisons.
Either way, USAF got a great engine IMO...
