milosh wrote:mixelflick wrote:And if all else fails, their J-20 will likely make short work of any Indian fighter put up against it. So that move too looks to have been a mistake IMO...
Can you explain were exactly? Over Chinese air space? Right but that would happen even if they had F-35/Su-57 or any other stealth, Chinese would have lot more J-20 and will have support from their ground radars.
But in Indian airspace J-20 is pray not hunter. Indian radar and sam network plus very capable AWACS (they have best AWACS in world) will locate it easily.
Btw Su-30MKI are getting R-37M as part of Su-30MKI big upgrade program. Missile was tested by Indians in 2019.
It look like India is getting engine tech from France:
https://economictimes.indiatimes.com/ma ... 935614.cmsWell if that is true Rafale deal is superb and probable it would increase chance of Rafales in new MMCA program.
Which AEW&C aircraft are you talking about? Netra seems to be a balance-beam design a la KJ-200, which implies a smaller radar aperture. Indian A-50EI seems to be bearing the EL/W-2090, considered the "most advanced AEW&C system in the world"... as of 1993.
As regarding the Su-57's internal weapons load, the bays are roughly 1 meter each by about 4.6 meters (external), not including the internal accommodations for the weapons which tend to reduce usable bay size. It's possible to achieve 10 missile loadouts, but only in the same way you can stuff 12 SACMs in an F-22; i.e, you reduce the missile size.
The other way to do it, and I'm trying to locate images of the Su-57 with its weapons bay open, would be to stack the missiles in a two-layered fashion. That is to say, the first missile is affixed to the bay doors, as with the F-35, but the second missile would be launched from the ejector attached to the weapons bay. That's contingent, of course, on the Su-57 having a sufficiently deep weapons bay for that to work.
Personally, as someone who bashes the J-20 as a disappointment (in part because of the poor capacity of the weapons bay), if the Su-57 bays are deep enough to double stack it could make the Su-57 impressive in its own way. It might not be a decent stealth BVR fighter, but it'd have the capability to launch heavy strike weapons from well beyond stand-off distance.
