sprstdlyscottsmn wrote:milosh wrote:This is why I don't use internet estimates which is +19tons for weight, that is why I used 20tons, it is higher then what even some serous sites estimated and more realistic.
If you compare the top view of the F-22 to the J-20, and move the F-22 tails up to a canard position (to mimic the arrangement of the J-20) you see that the fuselage of the J-20 is colossal compared to the F-22 while the wing sizes are largely similar. The F-22 weighs 22 US tons, 20 metric tons. How do you propose the larger aircraft of similar design is not going to be 21-22 metric tons empty?
Because not everything is clear from outside, you can't judge plane based purely on dimensions and shape, for example F-22 have this inside:
J-20 have this:
See some noticeable difference? And do you think it doesn't impact weight noticable?
Second example is F-23EMD, NG was marketing it not noticable heavier then YF-23 but it was longer airframe and not demostrator.
So how they plan to do that? Using much higher % of composites.
So materials are surely different then in case of F-22, in fact if you look F-35 and Su-57 (we have data for both) both birds using more composites then F-22 and interestingly more aluminium, titanium is something Russians have a lot but still they use less Ti compared to Su-35 to reduce Su-57 weight.
And then we have Su-34 and MiG-31 which are 21-22tons, so I really don't buy idea J-20 is something like 21-22tons just because F-22 is 20tons.
@charlielima223I never wrote Su-57 intake is same as F-23 it isn't what I wrote F-23 would need radar blocker to hide engine compared to F-22, and I think some kind of blocker was mentioned on yf-23.net
Su-57 CGI picture of intake ramps was done based on drawings, reason why Su-57 have quite strange intake mouth is integration of ramp and intake to hide engine from radar in supersonic flight.
Moving Levcon and canards are totally different control surfaces, and Su-57 doesn't need to use levcon movement at all it could still fly without problem, J-20 without canards not so much. Also levcon movement is nowhere near big as in case of canards.
