tacf-x wrote:The reason the Rhino is hated is because of its poor kinematic performance against even its little brother the Hornet. I'm serious, in terms of ACM the Super Hornet is allegedly not quite up to par with the regular hornet. But still, as previously stated, the Navy never wanted the SH to be an air superiority fighter. That was never the goal of the SH anyway. It was meant to be an attack aircraft with secondary air-to-air capability to at least SORT OF compensate for the loss of the A-6 Intruder from the Navy's fleet. It was presented as a low cost, low risk alternative to other expensive programs like the ATA and A/FX, and Congress approved it.
The SH features an increase in range, mission radius and loiter capabilities in the subsonic regime due to more lifting surface placed fitted to it with more internal fuel to carry.
The SH's weak engines result in poor acceleration and poor climb. Also with the high transonic and supersonic drag that ensures the top speed is heavily limited too. From a kinematic standpoint the SH doesn't really bring much to the table.
But again, you wouldn't compare a flanker to an A-6 so why compare a Flanker to the SH?
It's not so much the SH is hated as much as it's resented. The reasons for that go back to when it first started. Keep in mind this is an academic discussion, we don't have the keys to the TARDIS to go back and try and change things.
SH was not selected by the Navy, it was imposed on it by DoD. That has to rankle. During its formative times, there was a lot of smoke and mirrors and sleight of hand regarding its justification, capabilities, testing and cost. That didn't go over very well, either, as there were alternative strategies that offered more capability with less R&D money and time (but more O&M cost).
The Hornet/Super Hornet has always been very powerful, and with the SH they pretty much owned NAVAIR, causing less than enthusiasm. A number of programs were canceled/sacrificed in order for the SH to flourish. As time passes, and those involved in said programs fade away this particular aspect will no doubt diminish
SH was not presented as a low cost/low risk alternative to ATA & A/FX. ATA collapsed under its own weight before SH came about. In fact, the rationale for developing SH was that it would be an interim aircraft to address a strike shortfall until the
real strike a/c, AX, was fielded. AX became A/FX partly because it was felt that more fighter capability would be needed than USN would have with SH. What happened with Congress, after the controversial birth of SH, was that it stated a few years later that it would fund the development of A/FX or SH but not both. Whether it was because of the power of the Hornet lobby or that saying about, "A bird in the hand...", NAVAIR chose the latter, and so here we are.
The SH's range increased was advertised as being due to reduced drag in the "non-cruise" portion of the flight. It carries larger external tanks than the legacy Hornet, MDD itself showed that those same tanks could be used by the Hornet A-D. It carries significantly more internal fuel than the legacy models, but the main purpose for that is reportedly to compensate for the higher fuel burn of its engines.
With respect, it's unfair to characterize SH's engines as "weak". They produce every bit of thrust that was asked for, and are superb performers, following in the tradition of the J79, F110 and their parent, the F404. Keep in mind that SH's engines put out more thrust than that of the Eurocanards (Yes, Gripen NG uses the F414, but it only has one of them). In fact, Rafale, if the various range/loadout specs are to be believed, meets or exceeds SH's range/payload in a number of areas and is noticeably more agile. Yet the Rafale's M88s don't even put out as much thrust as the legacy Hornet's F404s.
It is correct that SH is primarily a strike aircraft, but saying it shouldn't be compared to a Flanker because we don't compare A-6s to the Flanker is, IMHO, not a valid point. Here's why: When we had A-6s, we also had F-14Ds. Those who have Fencers or Fullbacks (which is a pretty agile machine) also have Flankers for that role. The USN, though, only has SH. So, it has to function as our "Flanker", and since that's the case, the comparison is apt.
IMHO.
Again, this is mostly an academic exercise; it's 2012, not the early 1990s when we had other options, so we need to be looking forward, not back.
