marsavian wrote:Your percentages are arbitrary and don't really equate to effectiveness.
I understand that, what I'm saying is you're buying a burger with a side of fries and you're just eating the fries. Yes, I know they are extra large fries and are more than enough for what you need. But what if you can just buy fries. The Japanese think they can make their own extra large side of fries. Hey it might cost more and might not be as good but its theirs
marsavian wrote:The F-35A can do everything a F-22A can do in an air-air role except supercruise.
The F-35 is the most capable air dominance fighter ever behind the F-22. But having said that, there are things the F-22 can do that Japan or other countries may want as well.
1. Super Cruising at 60,000 feet with 6 BVR missiles makes you almost invulnerable specially if you're a stealth fighter.
2. Carrying 9x in internal bays
3. Supersonic maneuverability which is also useful in a BVR fight. This was a primary requirement for the ATF program.
There are certain luxuries the F-22 offers in A-A that the F-35 just can't do because it was made primarily for strike.
The fighter pilot podcast said it perfectly.
https://www.youtube.com/watch?v=ITCerewkIQEWe were designed for a different mission set like SEAD/DEAD. Where the Raptor was designed solely for air dominance we were designed for a more multi role platform.
If you were given a choice for what to bring in an A-A mission, which one would you choose between the F-22 and F-35. I think most people would choose the F-22. But since it's no longer in production and is banned for export, you have to go with the F-35. I'm not saying its a bad choice but if you had a choice, you'd go with the Raptor on that fight.
Well, the Japanese feel like they have a choice. They can make their own Raptor, maybe even a little better since it will be developed nearly 15 years after the 1st F-22 became operational.
Japan's XF-9 engine has max rated thrust of 33,000 lbs in full AB and TVC nozles that deflect 20 degrees in the entire circumference. Slap 2 of those in a 40,000 pound air-frame and you got your own pseudo Raptor.
Will it be expensive? Sure....but this is Japan, richer than any European country in case we forgot.
The UK, France, Russia and even Turkey are developing their own fighters, why not them.
