wil59 wrote:Super Cruise in Super sonic Speed
which means the engines can power the Aircraft without burning any flames,
even in dry thrust the engine produce flame
wil59 wrote:usually the Plane can glide at super sonic ranges without wasting much more energy and Engine power,
supercruise use less fuel compared to superburner but it still use quite a lot fuel
wil59 wrote: in a Test mission set by IAF, the Rafale Carry's four Air to air missiles along with two guided bombs, and at the speed of Mach 1.4, and impressed the IAF evaluation team,
can you give a link for that claim , i havent read in any official link that Rafale can supercruise at mach 1.4 with 2 guider bombs
wil59 wrote: Super cruise can be used to defeat most Heat seeking or IR Guided missile, which is usually tracks the Target using the Heat signatures, during dog fights or Close combat one was always try to escape from the Red zone with full power, that means he can go full after burner to achieve maximum speed, which also makes the missile for easy target, most of the time the IR guided missiles targets the Flares and the sun's because of Sun's heat spot. But with the Help of Super cruise without making Heat signs the Rafale can escape from the red zone at higher speed with the small design it can also maneuver at high rate to evade the missile.
1) supercruise does produce heat , alot of heat actually ( eventhought it still produce less infrared signature compared to after burner
2) the method you described will only work again first gen IR missiles like Aim-9A, Aim-9B , it is uselss again modern all aspect IIR missiles
2)
