wil59 wrote: which means the engines can power the Aircraft without burning any flames, usually the Plane can glide at super sonic ranges without wasting much more energy and Engine power, almost all the contenders in MMRCA comes with super cruise, but Rafale only performed better with the Sneccma M88 Engines, in a Test mission set by IAF, the Rafale Carry's four Air to air missiles along with two guided bombs, and at the speed of Mach 1.4, and impressed the IAF evaluation team,
I'd like to see any credible source for that claim.
wil59 wrote: Super cruise can be used to defeat most Heat seeking or IR Guided missile, which is usually tracks the Target using the Heat signatures, during dog fights or Close combat one was always try to escape from the Red zone with full power, that means he can go full after burner to achieve maximum speed, which also makes the missile for easy target, most of the time the IR guided missiles targets the Flares and the sun's because of Sun's heat spot. But with the Help of Super cruise without making Heat signs the Rafale can escape from the red zone at higher speed with the small design it can also maneuver at high rate to evade the missile.
I seriously doubt supercruise is that useful in close combat as it takes quite a bit of time and space to accelerate to supersonic speed, especially on dry thrust only. From what I've read and heard, even F-22 usually accelerate using AB and then supercruise. While AB burns much more fuel, it also shortens acceleration time a lot and thus can actually be more economical.
Modern missiles are pretty oblivious to sun and even flares. Especially the ones with imaging seekers won't be fooled by sun at all.
