TCTO Compliance
How do I get access to all applicable TCTO's for a fleet (C-130A's) to ensure they comply with what is applicable? Thanks for all the help guys!
Sometime back I compiled a list of applicable TCTO' as they relate to AD's. Since then the operators followed AD's. I did the reseach at WRALC. Contact any of the FIREFIGHTERS they can assist you. The results were incorporated into Inspection guide 182 FAA approved you will need this to start your Inspection Program.
wbh wrote:Sometime back I compiled a list of applicable TCTO' as they relate to AD's. Since then the operators followed AD's. I did the reseach at WRALC. Contact any of the FIREFIGHTERS they can assist you. The results were incorporated into Inspection guide 182 FAA approved you will need this to start your Inspection Program.
So is it safe to say that the TCTOs have been incorporated into either an AD or some other means of compliance? My only hold up is that the TC states to verify the applicability of all TCTOs but there is not a comprehensive list that I can find to verify if my aircraft are up to snuff. I know the SMP is out there but it is not up to date from what I can tell and finding information for the C130A is far and few between when it comes to compliance.
you can get copies of TCTO's from Aeronautical Tech pubs 1-719-522-2000
You will need: TCTO,s 1C-130A -851 , 846 , 1271 , 845 , 1358 , 1352 , 1294 , 1398 , 1285 , 1309 , 1304 , 1430 , 1357 ,1400 , 1418 , 1287 , 1458 , 1420 , 1320 , 1456 , 1493 ,1497 , 840 Then go to AD,s after that. Use IPG-185 to set up your inspection program.
