Masive upgrade for C-130's
The US Air Force is pushing a massive technological upgrade of its war-tested C-130
Scout Warrior
Kris Osborn
The Air Force is progressing with a massive technological overhaul of its war zone-tested C-130 aircraft, giving the platform new radios, digital avionics, collision avoidance technology and reinforced "wing-boxes," service officials said.
The Air Force remains vigilant about its C-130 fleet to ensure the air frames, wing boxes, avionics and communication systems remain safe and operational well into the 2030's and beyond. This is particularly true of the older 1980s-era C-130Hs, Air Force developers explained.
“The thing that causes the greatest risk to the airplane is the life of the wing. We monitor the wing of the aircraft and as the wings get past their service, life we bring the airplanes back in and bring in new structures -- with the primary focus being the center wingbox which is the area where the wings mount to the fuselage,”Col. Robert Toth, Chief of Tactical Aircraft, Special Operations and Combat Search and Rescue Division, told Scout Warrior in an interview several months ago.
As for when a C-130 is in need of a maintenance upgrade to preserve and maintain service life, the Air Force uses an assessment metric referred to as “equivalent baseline hours.” The wing-boxes are changed once the aircraft reaches a certain “severity factor” in its operational service time. This is necessary because the wear and tear or impact of missions upon and airplane can vary greatly depending upon a range of factors such as the altitude at which a plane is flying, Toth said.
“Low-level flight may be three to four times the severity factor of flying at a higher level,” he said.
Also, by January of 2020 the entire fleet of C-130s will need to comply with an FAA mandate and be equipped with systems that will relay aircraft position to a greater fidelity back and forth between the airplane and the air traffic management authorities, he added. This will allow them to sequence more aircraft closer together and enhance an ability to move commerce.
Avionics Modernization Program, Increment 1 involves adding new 8.33 radios to the aircraft to improve communication along with initiatives to upgrade cockpit voice recorders and digital data recorders. C-130s will also receive new collision-avoidance technology designed to prevent the planes from hitting terrain or colliding with one another mid-air. Inc. 1 is currently ongoing and is slated to complete by 2019.
AMP Inc. 2 involves a larger-scale effort to integrate digital avionics throughout the airplane. Inc. 2 will require nine-months to one year of work and be completed by 2028, Toth explained.
“This will allow us to bring the airplane from analog to digital, integrate a glass cockpit and use touchscreen displays. We will get away from the old systems of avionics where we had dial-driven instrumentation to where it is all digital. This makes us able to process a lot more information,” Toth said.
As part of the C-130 modernization calculus, the Air Force will consider retiring some C-130Hs and replace them with newly-built C-130Js; the service has authority to acquire an additional 20 C-130Js, Toth added.
“We continue to evaluate where it makes sense to retire and older airplane and instead put that money into buying new airplanes,” he said.
AC-130 gunships make up a small portion of a fleet of roughly 500 C-130 planes throughout the Air Force and Special Operations Command, Toth explained.
The cargo planes are used to airdrop supplies, equipment, weapons and troops in forward deployed locations.
As a propeller-driven aircraft, the C-130s are able to fly and land in more rugged conditions and withstand harsh weather such as obscurants. The propellers make the aircraft’s engines less susceptible to debris flying in and causing operational problems for the engines.
“It really allows you to do that tactical movement of equipment and personnel to take the airplane to the last tactical mile. A lot of our transport strategic airlifters are meant to go to a hard runway to a hard runway somewhere and then they turn over the cargo to be moved to the forward areas to a C-130 or a vehicle. The C-130 allows you to take that cargo and land on a smaller runway or an unimproved airfield,” Toth added.
C-130s are used for domestic, international and warzone transport including homeland security, disaster relief and supply deliveries, among other things.
“There are probably missions that have yet to be dreamed up for the C-130,” Toth said.
The fleet consists of 135 more modern C-130J aircraft and 165 older C-130Hs which have been around since the 80s, Toth explained.
Also, MC-130Js are specially modified airlifters engineered to transport Army Green Berets, Navy SEALs and Army Rangers.
“They are essentially a C-130J further modified with defensive systems with radar countermeasures and infrared radar and advanced sensors for specialized missions. They also can perform in-flight refueling,” Toth explained.
Scout Warrior
Kris Osborn
edpop wrote:The US Air Force is pushing a massive technological upgrade of its war-tested C-130
Scout Warrior
Kris Osborn
Interesting. No mention of Boeing's failed attempt at doing AMP. The best plan would be to inject C-130J tech into the older models and realize shared logistics, training and economies of scale.
Exactly. How long have they been trying to do this? AMP was 20-something years ago?
C-130 has now been around for 60 years and thus proved its reliability. For each year, the new improvements. Edpop now writes about "giving the platform new radios, digital avionics, Collision Avoidance Technology and reinforced" wing-boxes. "I only hope that everything else that is important for safety and performance continue on to evolve in the same way. Five years ago, crashed a C-130 right into a mountain wall between Sweden and Norway, and all on board perished. It flew simply too low height. Crash Investigation could not find any technical fault. The responsibility was considered completely lie on the pilot and air traffic control.
I,m glad that the Boeing failed AMP program got mentioned. I was the Senior systems Engineer for AMP at the Competitor's site. The bid was let somewhat unfairly ,with some aid from Gov't officials(who were later convicted). The contract went forward anyway , but I could see that it was doomed for failure due to the approach taken . The only way to do any AMPS Mod is to remove all traces of the original Avionics suite and start from scratch with an Electrical system upgrade. If what I have briefly described is performed then A. standardization is possible and B. there is large reduction in aircraft Operational Weight Empty (OWE). I know this to be a fact for that is what was done on the "Pre Amp" prototype LAC 3035. The Standardization is obvious and the weight is largely due to wire removal and removal of old style generator control units and T/R unit bleeder resistors. In addition most modern Avionics is 28 VDC and much lighter than the "old stuff".
Hi Guys
I need to gain access to a c-130j for 3D scanning. It’s for the following project:
https://www.airforce-technology.com/new ... f-wingtip/
Can you let me know if there are any users who may be able to point me in the right direction to scan one?
All the best Andy
All the best Andy
