FULL PDF: Poststall flight in close combat
https://arc.aiaa.org/doi/abs/10.2514/6.1983-2120
A computer simulation of close range gun fight between aircraft A and B.
Aircraft A: has far better conventional turn capability than fulcrums and flankers (aircraft A can acheive almost 30 deg/sec SUSTAINED!)
Aircraft B: similar to F-35, it can perform J-turn. However its other performances are inferior to F-35. Its T/W is only 0.75.
Result: Aircraft B dominates the dogfight. Even we give some initial positional advantage to A for free, this advantage is quickly neutrlized in less than one turn.
FULL PDF:
FULL PDF:
Loose speed = Loose fight.
You can add a ton af math profs, and another ton of simms to the game.
In the end?
Loose speed = loose fight.
Believing in a 100% kill probability (or the lucky shot) is like playing the lottery. => Extremely few winners.
Wanna bet?
In the end?
Wanna bet?
Lose vs. Loose vs. Loosen: What’s the Difference? https://writingexplained.org/lose-versu ... difference
vilters wrote:Loose speed = Loose fight.
In the end?
Wanna bet?
This is an oversimplification.
Yes, speed is life, and in general one wants to keep one's energy up. But as QS has stated here before, many a lesser experienced pilot has "energy managed" himself into a mort. The really good pilots know when to trade their energy chips in for an angles advantage and get the kill. It all "depends", but it is what makes a good Hornet pilot so dangerous.
What appears to make the F-35 so dangerous is that it apparently can do both -- either play the energy game, or play the trade-energy-for-angles game (i.e. high alpha). So the F-35 would appear to really reward the savvy fighter pilot.
In the end?
Wanna bet?
So Cobra and all those other fancy Flanker maneuvers are useless right? Right?
sferrin wrote:vilters wrote:Loose speed = Loose fight.
In the end?
Wanna bet?
cobra is useless Because no matter How much angle It pitch up, It will be bounced back immediately, neutralizing the total angle of pointing.
The maneuver studied in this paper is J turn , which has 180deg heading reversal. It has Very high effective angle of pointing.
garrya wrote:IIRC, they found out from X-31 test that post stall maneuver can be countered by going vertical
My favourite part was where the NASA author stated they had pretty much just relearnt a lesson from WW1
