Can cruise missile overtake a Jumbo jet?
eloise
Unread post02 Dec 2018, 17:57
Boeing 747 can reach top speed of Mach 0.92 at high altitude
A subsonic cruise missile like JSM can reach top speed of Mach 0.95 at sea level with 1:1 T/W.
so can a cruise missile like JSM catch up with a 747 running away at top speed if it is launched from tail aspect ? Assuming the starting distance is 15-20 km apart, and JSM can fly for maximum 550 km in hi-hi-lo profile
If the answear is “it can’t”, does anything change when the engagement started from the beam aspect
How big is the no escape zone if we used a subsonic cruise missile like JSM for anti air purpose against AEW&C such as E-3, DEW carrier such as YAL-1, strategic bombers such as B-52?
I asked these question because the way their IIR seeker with ATA work, you can input anything in their library and they will seek out that
sprstdlyscottsmn
Unread post03 Dec 2018, 06:53
We don't have enough information about the missile at this point. We don't know how fast it can go at altitude or what it's maximum altitude is. The 474-8 can do 0.92M at 50,000ft.
garrya
Unread post03 Dec 2018, 10:35
They can't
JSM and NSM both use TR40 engine with 16.400 feet maximum operating altitude
LRASM use F107-WR-105 turbofan engine with 30.000 feet absolute operating altitude
MALD and JSOW-ER use TJ-150 turbojet engine with 29.500 feet maximum operating altitude
sprstdlyscottsmn
Unread post03 Dec 2018, 14:22
Excellent work garrya.
eloise
Unread post03 Dec 2018, 14:59
Why don’t these engine work at higher altitude ?
pron
Unread post03 Dec 2018, 16:42
garrya wrote:They can't
The NSM uses the TR40, but they switched to Williams WJ38-7K for the JSM.
Janes IDR Dec 14 report on JSM says that the NSM TR-40 was replaced by a Williams WJ38-7K on the JSM partly because the JSM fuselage had to be narrowed to fit the F35 bombay and partly to attract US interest in selecting it for the F35A and F35C.
sferrin
Unread post03 Dec 2018, 19:41
If you want something like this see MALI:
"The MALI (Maniature Air-Launched Interceptor) was an armed derivative of MALD, for possible use against cruise missiles. MALI had a sharper nose profile, increased wing swep, and a more powerful (0.53 kN (120 lb) thrust) TJ-50M engine for short supersonic performance. An IIR (Imaging Infrared) seeker was used for terminal homing on the target, and mid-course guidance was via a command link to air surveillance platforms like the E-3 AWACS. The MALI has undergone a test and development program, which ended in December 2002, when the first supersonic flight was made. "
http://www.designation-systems.net/dusrm/m-160.html
eloise
Unread post04 Dec 2018, 02:15
sferrin wrote:If you want something like this see MALI:
The attachment NewsMedia_229279.jpg is no longer available
That what i thought about, unfortunately, it was cancelled
Furthermore, i can't find even a single photo of MALI, even artist drawing is extremely rare, i have no idea what the system looks like.
Flying missile rail seem like a good alternative?
Unread post04 Dec 2018, 12:48
F-15 would be a better launch platform. You could double your weight and scale performance upwards.
If it's a cylinder with fold out wings you are more flexible in delivery options. Flying wings impair carriage of other ordnance.
sferrin
Unread post04 Dec 2018, 14:13
madrat wrote:If it's a cylinder with fold out wings you are more flexible in delivery options. Flying wings impair carriage of other ordnance.
The Russians are pretty much the expert there. Compare the compactness of P-700 (Shipwreck) and P-750 (Meteorite), with multiple hinge points (and both tube-launched), to something like Regulus 2 with none (and needed a friggin' hangar):
eloise
Unread post05 Dec 2018, 10:02
madrat wrote:F-15 would be a better launch platform. You could double your weight and scale performance upwards.
What do you mean?
zhangmdev
Unread post05 Dec 2018, 17:37
Airliners use huge turbofan engines with very high bypass ratio to optimize high altitude cruise. Those very small turbofans on cruise missiles don't have enough size/frontal-area/mass-flow-rate to opearate in the thin air efficiently.
Unread post06 Dec 2018, 02:07
What do you mean?
The F-15 has more ground and wing clearance, and a strong pair of hardpoints.
geforcerfx
Unread post06 Dec 2018, 08:10
I always thought using a cruise missile to intercept targets at long ranges would be effective, unless your defensive then you prob want more speed. I figured for effectiveness against both fighters and support aircraft you would need a sub munition system. Basically big missile carries a (few) little missile a long distance from the shooter and then unleashes his friends. Gives you a more nimble missiles to go after fighters, and gives you multiple missiles (potentially) to go after larger support aircraft increasing chances of hits against counter measures. Submuntion prob adds to much complexity, plus the need has kinda fallen in my eyes since the west is going heavy stealth. I could see it coming back but not till later in the F-35's life and who knows what it will be packing for sensors and stealth upgrades by then.
Users browsing this forum: Google [Bot] and 22 guests
